difference between 3/4 ton 14 bolt vs. 1 ton 14 bolt
Discussion in 'The Garage' started by k2-k5, Feb 18, 2004.
  1. k2-k5
    k2-k5 1/2 ton status
    Sep 30, 2003
    285
    Vancouver, WA
    Like the subject says. Are they basically the same? Payload the same?
    I have heard there is a brake size difference.
    Spring perch width difference.
    Is this true and is there any other differences?
  2. mud390
    mud390 1/2 ton status
    Oct 31, 2002
    1,210
    Little Rock, Arkansas
    I'm not sure about the load rating, but the brakes are different as well as the spring perchs. The 1 ton has the larger brakes, 3.5 inch drums (I believe, corrrect me if I'm wrong) and the 3/4 ton has 2.5 inch drums. There are kits to put disks on there though. The perches are closer together on the 1 ton axle as well.
    Kris
  3. cybrfire
    Dec 15, 2002
    15,142
    569
    Iowa
    Spring perch difference is the biggest one. I have seen 3/4 tons with the bigger and smaller drums so just depends on what you get. I think everything else is the same.
  4. jakeslim
    jakeslim 1/2 ton status
    Sep 18, 2002
    2,686
    Napa, CA
    i bought the 3/4 ton 14ff because the spring perches line up perfectly. I did not want to have to relocate the perches from the 1 ton. Other than that, its just the brake difference you mentioned.
  5. k2-k5
    Sep 30, 2003
    285
    Vancouver, WA
    I am swapping into a '72 blazer is the 1 ton 14 bolt a direct bolt up for my spring width?
  6. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    Yes.
  7. 88Silverado
    88Silverado 1/2 ton status
    Mar 13, 2003
    2,664
    Quartz Hill, So. Cal
    I thought the 14B 3/4 ton was the SF 9.5" and the 1 ton was the FF 10.5 gear /forums/images/graemlins/confused.gif
  8. cybrfire
    Dec 15, 2002
    15,142
    569
    Iowa
    Some 3/4 tons had the SF but most I think have the FF. the semi Floater is kind of a heavy half or light duty 3/4 ton I think.
  9. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,472
    5
    Olympia/Lacey, Washington
    I snagged my 14bff with the 10.5" ring gear and factory locker from a 2wd 3/4 ton pick up. Bolted right in the '89 Burb. the only thing i had to do was get the conversion u-joint.
