Difference between 3/4t, 1t 14bolt FF
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by cegusman, Dec 3, 2001.
  1. cegusman
    cegusman 3/4 ton status
    Apr 25, 2001
    6,793
    Houston/Katy, Tx
    What is the difference between a 3/4t 14 bolt FF and a 1t 14 Bolt FF, Is it just the axle shafts?
    Houston, TX
  2. Esteban86K5
    Esteban86K5 1/2 ton status
    3,712
    Bakersfield, CA
    The only difference is the position of the spring perches and shock mounts. Everything else is the same.
    <font color=blue>It's easier to teach a child than to fix an adult.</font color=blue>
    <a target="_blank" href=http://community.webshots.com/user/geltyone>Webshots Pics.</a>
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    The spring perches and shock mounts are in a different place. The 3/4-ton version will bolt right into a K5. The 1-ton version requires some cutting and welding first.
  4. SlyDog
    SlyDog 1/2 ton status
    Oct 23, 2000
    3,035
    Scottsdale, Arizona
    Yup, what Estaban said.
    <font color=green>[​IMG]1977 K5 GETTIN IT AWN[​IMG]</font color=green>
    BUILT NOT BOUGHT
  5. wayne
    wayne 3/4 ton status
    Feb 1, 2001
    6,178
    Carlisle, Pa
    Axle shafts are the same as long as they are single wheel axles. The dually had 2 different width axles, 1 was for a standard truck and 1 for a cab and chassie model. The difference is the brakes and the spring perch and shock mounts. I have seen 3/4 ton ones with the big brakes like the 1 ton but usually they are smaller.
    See <a target="_blank" href=http://coloradok5.com/gallery/Waynes-Toy>Project Mighty Mouse</a> here.
    <font color=blue>Wayne<font color=blue>
    <font color=blue>Happy Trails<font color=blue>
  6. Chris Demartini
    2,406
    Dumont NJ 07628
    <font color=blue>Besides the spring pads, the drums are larger on the 1 ton 14 bolts
  7. thatK30guy
    Jan 12, 2001
    32,076
    55
    3/4 tons can have either one of two different drum sizes. 11" and 13".
    1 tons have 13" drums but are 3.5" wide, where the 3/4 ton 13" drums are only 2.5" wide.
    Other than the spring perches and shock mounts being different, and the drum sizes, EVERYTHING ELSE IS IDENTICAL. [​IMG]
    I'm not picking my nose...I'm just pointing at my brain!! [​IMG]
    <a target="_blank" href=http://coloradok5.com/gallery/thatK30guy>The K30 Collection</a>
