Difference between 4x4 th350 and regular 350???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by rebel222, Jun 18, 2002.
  1. rebel222
    rebel222 Registered Member
    Aug 21, 2000
    58
    Louisiana
    Is there a difference between a 4x4 th350 and a regular? I think I need a rebuild because my truck kicks real hard when I either come to a complete stop or when I start going from a stop. This doesn't happen every time but the majority of the time. Also, sometimes it doesn't shift into third. If it needs a rebuild, I don't wanna pay 700-800 dollars for it to be done because I wont get that much out of a new tranny. I was planning to buy a slightly used(10,000 to 20,000 miles) tranny and just pay labor to have it installed. Any help will be greatly appreciated.
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    The only difference is the output shaft on a 4x4 tranny is much shorter than a 2WD tranny. Also if it is a K case then it is different from a 2WD case in that a K case is thicker.
