difference between a 14.5 and 12.5
Discussion in 'The Garage' started by 69K5, Jun 29, 2003.
  1. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    I was looking at national tire and wheel at some ground hawgs. they had some hawgs that were 36x14.50rlt and 38x15.50r15lt . both of these they had a 15 x 10 rim recommended. wont that make the center bulge up and wear faster?? you can check it yourself on the specs page and see if im just reading it wrong. also im assuming that (o.d.) means outside diamater of the tire.
    ground hawgs
    thanks
    nathan
  2. RingMaster4x4
    RingMaster4x4 1/2 ton status Premium Member
    Mar 4, 2001
    2,049
    Bartlett, Texas
    They really like the 15x10 wheel. I had my 40" tires on 10 and yes they did wear funny at full PSI. I had to run them at about 15-20 to make then wear right.
  3. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i thought that it would wear funny.do you have any probs running down the road with the lower pressure? (eg) bulging sides wandering, peolple flagging you down ect. i think a 12 inch rim would make my turning radius go to crap or rip some sheetmetal up pretty bad
  4. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    Nope, no problems. I am not that sure if a 12" would help that much. They said to run the 44" on 12" but I put them on 14" and I still have to run them at 20 PSI.
  5. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i looked at your pics to see if i saw any probs. where did you order the barts wheels from? i thought a 12 might help but make other problems. im just not sure about running that wide a tire on a narrow rim. seems like it might blow off if im doing donuts.
  6. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    They are Eaton wheels, but they are made by Bart. I got them from summit, they had the best deal. The prices were the same as everwhere else but they do FREE shipping. I never had any problems. (I do donuts too /forums/images/graemlins/thumb.gif) Donuts, Burnouts, ECT. No problems.
  7. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i didnt know eaton was made by bart. maybe that explains why i cant find any place on the net that sales barts super wheels. id like to see those 44's do a burnout
  8. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i found em summit had a link. thanks
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  9. boggerless
    boggerless 1 ton status Premium Member
    May 26, 2003
    22,728
    96
    dearborn heights, Michigan
    i ran my 40's on 10inch rims for over 4years, with no problem. and at the time i wasn't real good about checking my tire preasure. they were 17 in wide tread. /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif
  10. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I can do it. /forums/images/graemlins/thumb.gif /forums/images/graemlins/ignore.gif
  11. boggerless
    May 26, 2003
    22,728
    96
    cut the mustard? /forums/images/graemlins/k5.gifto /forums/images/graemlins/truck.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  12. 69K5
    69K5 1/2 ton status
    Nov 10, 2001
    1,544
    Monroe, LA
    i may end up with some 10's on there. i wont have 40's or 44's but between 36's and 38's. why does tyhis project keep getting bigger?????? /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
  13. RingMaster4x4
    Mar 4, 2001
    2,049
    Bartlett, Texas
    I know the feeling at first I was going to go 6" lift with 36" Ground Hawgs.....but you see how that is going. /forums/images/graemlins/rotfl.gif
