Difference between a dually axle and a single wheel axle???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by NewK5Guy, Feb 20, 2003.
  1. NewK5Guy
    NewK5Guy 1/2 ton status
    Mar 2, 2001
    556
    Alexandria, VA
    Deal is done./forums/images/graemlins/thumb.gif "Deal of a lifetime" should go down this weekend or next week some time. I bought the K3500 '90 1 ton with the plow/forums/images/graemlins/truck.gif. Only a few minor issues to deal with(plow solonoid, headlamps, shocks), but other than that, no lack of get up and go. But, guestion: Dude pulled out the original window sticker. Is that cool or what? Says the truck has a factory locking differential. Detroit or Gov-loc? Also, can't I just take off the dually rims and run a single wheel and be just fine? There's no track difference in the 2 axles, right? Drum to drum, dually axles and single wheel axles are the same measurement, with only the spring perches being different. Is that correct? /forums/images/graemlins/confused.gif
  2. nvrenuf
    nvrenuf Bazinga! Premium Member
    Jan 7, 2002
    12,774
    130
    Mobile, Al.
    It really depends on the what the truck is, is it a C/K series or R/V series? Is it a Dana 70 or 14 bolt? Look at the window sticker it will tell you which series truck it is. Also look for on the sticker and see if it says "Cab Chassis" anywhere.
    Generally speaking the single wheel and dually axles will be different. On a truck originally sold with a bed the dually axle is much wider than a single wheel axle, on a cab chassis the dually axle is usually much narrower.
    The front axle will also be set up with dually hubs so it will be considerably wider than a single wheel axle. All of this is not necessarily bad but they may make things a little difficult to convert to single wheels.
  3. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    i can get you exact width measurements soon when i get the 1 ton dually here, ive got a pickup SRW 14 bolt FF right now i can measure and compare to the cab chassis DRW 14 bolt FF soon, perches distance differs from 3/4 ton to 1 ton, 1 ton has narrower separated packs
    good luck
  4. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    Ooooops. Must be getting old. Keep forgetting all the pertanent info. Post edited. It is a K3500 with what I believe is a 14 bolt. The sticker doesn't say, but it does state "independant front suspension", "insta-trac transfer case", "dual rear wheels", "locking differential-rear axle", "rear axle-3.73 ratio", and "wideside pickup equipment". Unfortunately there are no order codes so I can't cross reference. Plus, it's kinda vague. If more than one rear axle was available, you'd figure the sticker would differentiate. The sticker does sate "ez-spec package-P3A1" if that helps. Guess I'll just have to wait. All will be truly revealed soon. I was just hoping to get a jump on it.
  5. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    PM me with those measurements. I'm very curious as I want to dump the dually setup and go single wheel. I have no desire to have to buy 6 new tires. Luckily the tires on the truck now are new, but it could use something with a bit more aggresive tread.
  6. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Does it have a pickup box, or is it a flatdeck?
    Sounds like a wide-track 14FF rear (w/Gov-Lock). There's a chance it may have a D70, and then you'd have a Powr-Lok.
    Since its IFS, you can take off the front hub extensions and bolt on single wheels. The rear you can just bolt on the single wheels, but it may look a little funny under a dually pickup box (if that's what you have).
  7. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    ill go ahead and get 14 bolt FF pickup SRW WMS to WMS measurement tommorrow, axle is in back of the pickup and wheels removed, so.,,.
  8. NE-RokToy
    NE-RokToy Registered Member
    Dec 24, 2002
    39
    Omaha NE
    Pickup wide side..... sounds like just a normal dually pickup. Don't know about the newer trucks but most dually's had a wider rear axle in the 74" range. Also why do want to get rid of the duals? if it going to be used for any kind of work its only a benifit.
  9. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    WEll, tire price was the thought. I really didn't like the fact I'd have to buy 6 tires at a time now. I have plenty of time to work that out as the tires on it now are new. I just wanted something with a more aggresive tread, like my old Mud Terrains. Sure, I could just take off the outer rims for summer driving, but then you get into empty fenders sticking out, uneven tire wear, and just a plain nuisance, at least to me. My ultimate plan would be to convert it to single rear wheel with matching bed. BUT, since it obviously a work truck, I may just fix the dually fenders, get some pain on it, and leave it alone. Can't deny that rear contact patch. I WOULD just go ahead and get 6 of the tires I like, but having to buy 6 Mud Terrains in about 31"(32"? whatever stock size is) would get a bit expensive.
    Eh. It's nothing urgent or important right now. Just a thought.
  10. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    It's a pickup bed, 6 foot I think. IT looked like a 14 bolt when I peeked under the last time I looked at it during daylight, but then, I could be wrong. Just have to wait until I finally sign the title. Is that power lock any better than the Gov-loc? I know all about the gov loc.
  11. SickboySS
    SickboySS 1/2 ton status
    Nov 24, 2002
    154
    Auburn Ma
    have you seen what some guys are doing to dualies? they're puttin massive assive front and rear tires with like 4" lifts under these trukcs, i'll try and find some pics....just leave it how it is, a daully will always be a hd work truck no matter how you play it off..
  12. NewK5Guy
    Mar 2, 2001
    556
    Alexandria, VA
    Yea. You're right. But, one can dream...
    Imagine...my dually plow truck with 44's.
    No way. Too damn much.
    But...
