Difference between a th350C and a th350
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 73K5Kid, Sep 26, 2002.
  1. 73K5Kid
    73K5Kid 1/2 ton status
    Sep 24, 2002
    583
    chandler az
    I've read that with a th350C you can get a 8-10% increase in fuel. How do you tell one from the other. With the th350C what do you give up.
  2. leadfoot067
    leadfoot067 1/2 ton status
    May 14, 2001
    1,563
    puyallup, washington
    a turbo 350c....has a lock up converter,it was GMs early attempt for gas mileage....the switches were known for braking and then the converter is locked up all the time causing the tranny to go out.......due to excessive heat...it will all bolt up the same as a regular 350t...but it will have an extra plug on the side of it..that you would need to wire to a switch to make the converter lock up properly.....thats about all i know about that.....hope this helps
  3. anatomiczero
    anatomiczero 1/2 ton status
    Jun 26, 2001
    418
    Washington
    It used a K case, metall bell housing instead of a plastic one and had 2 braces bolted to that. I had one in my Jimmy, but the wire for the converter lock up came off, anyways it crapped out eventually and now there's a regular th350 in there.
  4. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
