difference between Blazer 73-77 and 78-80 Body Bushings?
Discussion in 'The Garage' started by CheyenneKid, Aug 25, 2005.
  1. CheyenneKid
    CheyenneKid Registered Member
    Jan 12, 2003
    41
    Hey, what is the differnece between early style and later style body bushings? I know that GM changed the floorpan design in'77 and also moved the body mounts outboard of the framerails, but what actually changed with the bushings? Which bushings are different between the two kits in polyurethane? I'm supposing the front mounts for the core support and the front cab mounts are the same.
    Any knowledge is appreciated...
    Thanks,
    CK
  2. wazzabie
    wazzabie 1/2 ton status Premium Member
    Apr 17, 2001
    1,724
    11
    Washington State
    Fyi- in moving the mounts outward they are more prone to rust out
  3. thatK30guy
    Jan 12, 2001
    32,076
    55
    Not sure on the Blazers rearward mounts under the floors, but the cab and radiator mounts on the '81 to '91 are all identical shape and size. The '73 to '80 have different size and shape from the radiator to the rear cab mount.
  4. 6.2Blazer
    6.2Blazer 1/2 ton status
    Feb 24, 2000
    4,675
    26
    Ohio
    According to the parts diagram in the LMC catalog, the only difference between the '73-'77 and '78-'80 mounts is at the B-pillar (rear cab mounts/ behind front seat area) position. They call for the same parts for '73-'80 at all other mounting points.
  5. CheyenneKid
    Jan 12, 2003
    41
    cool. i bought a cheap set of body mounts for '73 to '80 on the eBay but I have a '79. Figgered I could make 'em work with some lathework or whatever I had to do. Can't be that different....
  6. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    The mount on the 73-77 for the B piller is taller than the mount for the 77 up. was the set you bought poly or rubber?
  7. CheyenneKid
    Jan 12, 2003
    41
    Poly. I'm going to poly from rubber. :saweet:
  8. CheyenneKid
    Jan 12, 2003
    41
    Think the xtra height will interfere with my clutch linkage? :dunno:
  9. 1979jimmy350
    Mar 24, 2004
    3,069
    Ann Arbor Mi
