Difference between D44 and 10b shafts?
Discussion in 'The Garage' started by 85mudblazin, Mar 27, 2005.
  1. 85mudblazin
    85mudblazin 1/2 ton status
    Mar 26, 2004
    3,951
    Austin,TX
    If they are the same strength then whats the difference between the two? what other differences are there between them??
    -Chris
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    I've been told the spline pressure angle is different.
    The length is different. Most 10-bolt shafts are 28-spline. D44 is 30-spline.
  3. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Inner shafts are different lengths, and i also heard something about the pressure angle of the splines being different as well.
  4. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    are the u-joints any different?
  5. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    Same U-joint as long as you aren't talking about a really old D44.
  6. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    hmmm CTM's in a 10b :grin:
  7. az-k5
    az-k5 1/2 ton status
    Oct 15, 2003
    2,774
    Phoenix AZ
    U-joints are the same along with stub shafts.
  8. 85mudblazin
    Mar 26, 2004
    3,951
    Austin,TX
    Sweet, thanks for the info yall :)
