difference between dana 44 and dana 60
Discussion in 'The Garage' started by fire dawg, Jan 24, 2005.
  1. fire dawg
    fire dawg Registered Member
    Jan 24, 2005
    28
    new mexico
    Does anyone know how to tell the difference between the two front ends without pulling the diff cover?
  2. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    D44 will have ball joints and a D60 will have king pins
  3. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    D60's are physically larger, the little "60" that is in the housing next to the cover, four bolts that hold on the the steering arm, KINGPINS, three ubolts, much larger lockouts, and eight lug hubs are all I can think of.
  4. 69TowRig
    69TowRig 1/2 ton status
    Dec 20, 2004
    288
    Raleigh, NC
    If I recall correctly D60s could be had in a 6-lug at some point. Not sure if that was a GM app though.
  5. jekbrown
    May 19, 2001
    45,032
    369
    Vancouver, WA, USA
    steering arm is a good thing to look at, dont think any 1/2 or 3/4 ton axle of any make uses 4 studs in the rectangular orientation like you see on a D60. Could be wrong. Anyway, if you know what a D44 hub looks like, you'll know a D60 when you see it, hubs are significantly larger.
    j
  6. sweetk30
    Nov 1, 2004
    25,553
    547
    horseheads , ny 14845
    old closed knuckle were big 6 lug. or aftermarket axle spec built could be ordered 6 lug like all others look for those things
  7. rjfguitar
    Aug 28, 2002
    9,097
    144
    california
    I don't think GM ever did but I could be wrong.
  8. atho
    atho 1/2 ton status
    May 14, 2003
    1,115
    Wayne County, Ohio
    Yes they could, but as semifloating rearends, and under IH and Dodge trucks with closed knuckles and a large 6 lug pattern.
    easiest way is to look for kingpin caps vs castle nuts.
    there was a gay oddball dodge d44 that used 3 u bolts and 2 studs (like a D60), just warning ya.
  9. dirtwarrior17
    dirtwarrior17 Banned
    May 14, 2004
    1,820
    Redding, CA
    Anybody got some pics of each?
    Also tryin to find out if i got taller gears stuffed in my diffs. It had a lift and steering braces when i bought it and i don't know if i got d44's or d60's. Has chrome diff covers so im wondering if they did anything to it when it got opened up.
  10. ryoken
    Jun 13, 2003
    29,624
    1,380
    Jersey Shore
    front D60 will have 3 u-bolts, instead of 4.
