Difference between front and rear gears?
Discussion in 'The Garage' started by odoa3, Mar 31, 2007.
  1. odoa3
    odoa3 1/2 ton status
    Mar 31, 2004
    1,638
    Anchorage, AK
    Is there a difference in gears between a front and rear Dana 60? Found a set of gears for a good price, but it sounds like they were going to go in a rear Dana 60 - I would hate to buy them and find out they will not work in a front axle.
    Thanks.
  2. 4X4HIGH
    Dec 14, 2001
    22,063
    71
    Pleasanton, CA.
    Pretty sure the gears fit both front and rear unless it was a reverse rotation HP 60 front then they would be different.
  3. goldwing2000
    goldwing2000 Guest
    Exactly right. And reverse rotation = hi pinion, so it's easy to tell them apart.
  4. odoa3
    Mar 31, 2004
    1,638
    Anchorage, AK
    Thanks guys!
  5. Chrisblazzer89
    Chrisblazzer89 1/2 ton status
    Oct 12, 2006
    1,966
    Massachusetts 02301
    What about in front and rear 10B
  6. goldwing2000
    goldwing2000 Guest
    Samey-same, the only difference is in axle shaft spline counts, which won't change the gearset but it will change the lockers and axle shafts.
  7. dremu
    Feb 27, 2000
    15,970
    462
    East of San Francisco
    So are you saying that Hi Pinion went a different way from the rest of us? :haha:
    -- A
