Difference between SRW D60 rotor and DRW?
Discussion in 'The Garage' started by DukeBoy88, Jul 11, 2005.
  1. DukeBoy88
    DukeBoy88 1/2 ton status
    Oct 16, 2002
    315
    Jonestown Pa
    Is there a difference between the brake rotor used on a SRW D60 and a DRW D60? Advance auto lists the bendix rotor for SRW for 98.88 and the DRW for 82.96. They have different part numbers but I'm not sure what the difference would be. didn't look at them side by side cause they were special order. their cheaper rotors are reversed as far as prices go. thanks in advance.
  2. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    DRW rotors have smaller stud holes, they can be drilled out to work on a SRW application (see Billavista D60 bible for bit size). Since SRW rotors have the larger holes I doubt they would be a good choice for a DRW application (more difficult to center the rotor, also it would probably move around while braking).
  3. beater74
    beater74 1/2 ton status
    May 29, 2001
    1,749
    atlanta
    DRW rotors bolt to the hub, in other words the holes are threaded.
  4. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    The holes are not threaded, they are held to the hub with nuts & bolts. :thumb:
  5. beater74
    May 29, 2001
    1,749
    atlanta
    my DRW rotor and hub had no nuts. and the holes were threaded
  6. nvrenuf
    Jan 7, 2002
    13,079
    247
    Mobile, Al.
    :thinking: Maybe I've had too much to drink this morning... I'll have to look at mine again when I get home. :dunno:
