Difference in 1st & 2nd gen sterring boxes?
Discussion in 'The Garage' started by LKJR, Sep 8, 2003.
  1. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    whats the difference? shaft size? bolt pattern?
  2. 4X4HIGH
    Dec 14, 2001
    22,059
    69
    Pleasanton, CA.
    steering box should be the same up to 1980 I believe, those all used a flare type fitting then 1981 and on GM went to the O-ring style fitting on the hoses.
  3. ChevyCaGal
    ChevyCaGal 3/4 ton status
    Dec 16, 2000
    8,158
    Sacramento, CA USA
    Yup, had to figure that out that exact thing when I won a setup from WTO and was buying a 2wd box from muddytazz to send them....
  4. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    what about the input shaft?
  5. diesel4me
    Jul 24, 2003
    17,537
    923
    Massachussetts
    I've changed several leaky power steering boxes on GM 4x4's--in my experience the boxes from 69-72 fit the later models,with the hose changes noted already in the previous posts--the steering colum end of the box comes in at least two different spline diameters /forums/images/graemlins/deal.gif(I've only seen 2,maybe more?)--this means another trip to the boneyard to get the "rag joint" and steering shaft extention.This usually is discovered on sunday,when the truck is all apart,and the boneyard is closed! /forums/images/graemlins/angryfire.gif(nothing like calling a co-worker for a ride and he says"oh been fixing your truck again,aaayyy") /forums/images/graemlins/blush.gif
  6. LKJR
    LKJR 1/2 ton status
    Apr 18, 2000
    2,116
    Lubbock, Tx
    any chance of interchanging the input shafts on first gen boxes with that of a second gen van?
