difference in 305/350 haramic balancers
Discussion in 'The Garage' started by bryguy00b, Aug 11, 2003.
  1. bryguy00b
    bryguy00b 3/4 ton status
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok i looked at the one on the 305 in my blazer and then the one on my dads truck (which i know is a 350 for sure) and i couldt see much of a difference really. i was going to compare it to my truck to tell if it was really a 350 or if the PO was just BSing me..what difference am i looking for? /forums/images/graemlins/confused.gif
  2. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    they are the same.
  3. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    huh..i was told by someone they are different..
  4. 4X4HIGH
    Dec 14, 2001
    22,060
    69
    Pleasanton, CA.
    305 and 350 balancers are different.
  5. joshua
    joshua Registered Member
    Jul 31, 2003
    5
    They look the same, both fit and even share casting #. They are not interchangable because 305 balancer is lighter and has a hollowed out part not easily seen on assembled engine.
  6. bryguy00b
    Apr 7, 2002
    5,587
    Rochester, N.Y
    ok well whats the next trick to figure out what my engine is? were is a fairly easy number to fine on the block or something?
  7. dyeager535
    26,977
    Suffix code is going to be your best bet, as it will also tell you what vehicle it came out of, (if not original) performance, etc.
  8. diesel4me
    Jul 24, 2003
    17,540
    930
    Massachussetts
    There is a code stamped just under the passenger side cylinder head,a little "shelf"sticks out near the back of the altenator,its hard to see and most likely youll have to clean it with carb cleaner to read it--if your block was resurfaced it will have the code removed,in that case use the casting # on the drivers side rear of engine near the bellhousing,there are websites that have a listing of theese numbers,but I dont know the web adress--you can probably do search on "Google" and come up with it. /forums/images/graemlins/grin.gif
  9. 4x4Freak
    4x4Freak 1/2 ton status
    Apr 21, 2002
    792
    Lubbock, TX
