difference in doubler adaptors?
Discussion in 'The Garage' started by muddybuddy, Nov 14, 2006.
  1. muddybuddy
    muddybuddy 3/4 ton status
    Jan 29, 2004
    8,933
    Fairfax Station VA
    i was wondering if there was a difference in doubler adaptors between fords and chevy cases. i know fords use 31spline, and chevy is 32spline, i just mean the actual adaptor itself. all ford 205 cases are round pattern right. so if ive got a round chevy 205, could i use a ford adaptor? found one for a decent deal, and was just curious. thanks
  2. muddybuddy
    Jan 29, 2004
    8,933
    Fairfax Station VA
    any ideas? only reason i ask is because ive got a chevy 205 with ford 31spline input, and if a ford adaptor would work i could save a good bit of money vs. buying a new doubler adaptor.
  3. jays68yak
    jays68yak 1/2 ton status
    Feb 27, 2003
    973
    Gilroy, CA
    I do believe that the round bolt pattern is not symetrical....meaning the chevy might not bolt to the ford as it could be drilled the obosite way. Oh and I suck at spelling. You might want to search/post on pirate.
  4. b454rat
    b454rat 1/2 ton status Premium Member
    Jan 21, 2003
    3,009
    7
    Binghamton NY
    The round 6 pattern is off on two of the holes. Find the thread on 4l80 2wd to 4wd, it's 20-some pages, there was a pic in there of the two adaptors, and shows the difference. Not sure of the clocking diff either.
  5. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    yeah hes right... the patterns are mirrored. i dont see why you can have it remachined though
