difference in front springs??
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by K5Chris, May 14, 2004.
  1. K5Chris
    K5Chris 1/2 ton status
    Mar 11, 2002
    805
    New Orleans, LA
    is there a difference between the 88-91 blazer front springs and the pre-88 K10 springs?? if so, what? will 80's K10 lift springs fit on my '91 K5?
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    no but the 88-91 shackles are longer
  3. 4xcrazy
    4xcrazy 3/4 ton status
    Oct 31, 2003
    9,471
    5
    Olympia/Lacey, Washington
    there may be a difference in bushing and eyelet size.
    /forums/images/graemlins/dunno.gif /forums/images/graemlins/dunno.gif
  4. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    yeah, i did know that the shackles were longer.... but that shouldn't effect what springs fit.... i got a guy wanting to trade his 4" K10 springs for my 2.5" springs.
  5. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    88-91s use 1/2 inch bolts in the rear, earlier use 7/16
  6. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    so, can i use the 7/16's springs on mine?
  7. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    so, will the older springs work on my '91 if i use the 7/16 bolt, or not?
  8. nvrenuf
    Jan 7, 2002
    13,072
    245
    Mobile, Al.
    It's only the bushings and sleeves that are different (because of the bolts, like Tim said), the springs themselves are interchangable. If you do go to the smaller bolt bushings I'd swap the shackle too, otherwise you'll have a small bolt rattling around in a big hole.
  9. K5Chris
    Mar 11, 2002
    805
    New Orleans, LA
    ok, so i could keep my bushings, and put them into the older springs?
