difference in srw k30 and drw k30 lifts?
Discussion in 'The Garage' started by jackedjimmy350, Mar 19, 2006.
  1. jackedjimmy350
    jackedjimmy350 1/2 ton status
    Oct 20, 2000
    3,141
    Fort Smith, Arkansas 72901
    while trying to find a kit for my 87 k30 dually, i noticed all the lifts for k30's say "except dually". why is this? whats the difference?
    only thing i can think of off the top of my head might be the rear u-bolts...14 bolt and dana 70???
    any input apprecciated.
  2. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    4" tubes on th D70HD. Often the dually's have a swaybar too.
    I can't think of anything else :dunno:
  3. thor
    thor 1/2 ton status
    Aug 20, 2003
    512
    Wa
    While the 70hd has bigger tubes, they both still use the square style u bolts with the threads on the bottom that capture the spring and not the axle, so I can't see that making any difference.
  4. sweetk30
    Nov 1, 2004
    25,548
    543
    horseheads , ny 14845
    i did a lift on my cab chassie with 14ff and had to cut and turn the right shock mount on the axle. with the pinion corection in the block it moved it down and to the front. the shock wouldnt line up with the upper mount.
  5. u2slow
    May 9, 2001
    2,217
    BC Canada
    Hmmm... that would still be the same for a 1-ton SRW. :thinking:
  6. sweetk30
    Nov 1, 2004
    25,548
    543
    correct. :o
