Differences between 1/2T and 3/4T Dana 44?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Root Moose, Jun 10, 2003.
  1. Root Moose
    Root Moose Registered Member
    Oct 23, 2002
    11
    I've been searching around for an answer for this but haven't had any luck with anything definitive.
    Is the only difference between the two the brakes and the bolt pattern?
    They are all 30 spline shafts, correct?
    Anything else?
    r@m
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Brakes and bolt pattern is it. They are identical from the knuckles in. There were *some* 3/4 ton ones that had thicker axle tubes, but not really enough to warrant mention. </font>
  3. Root Moose
    Oct 23, 2002
    11
    Cool. Thanks.
  4. bigblock44k5
    bigblock44k5 1/2 ton status
    Jun 8, 2003
    396
    Hurlburt Field, FL
    I believe they also have different spindles for more weight carrying capacity also.
  5. Muddytazz
    Muddytazz 1 ton status
    Jun 30, 2002
    20,073
    Salem, Or.
    correct, spindles are different /forums/images/graemlins/thumb.gif
  6. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Spindles are not different from 3/4 to 1/2 ton.
    The difference is when they were made. The ealier ones, 1st design, had the smaller spindles and axle shafts.
    The later ones, 2nd design, had the larger spindles and axle shafts.
    Same for 1/2-3/4 ton.
    The only real differences are the lug pattern, brakes, and internal or external hubs. For the most part though, I think, the 1st designs had the external hubs 2nd design had the internal hubs.
    I'm not sure the cut off years for the 1st and 2nd design- I think its right around '74-75. /forums/images/graemlins/thumb.gif
  7. Root Moose
    Oct 23, 2002
    11
    What is the difference between an internal/external hub? Which is stronger?
