Differences between D44 and D60
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Blazer79, Feb 26, 2002.
  1. Blazer79
    Blazer79 1/2 ton status
    1,816
    Guatemala, Central America
    Guys!! I'm so excited. I just came from a junkyard and they just received an old suburban with what appears to be a front D60 and a 14bolt!! The guy just wants the equivalent in my local currency of US$500 for BOTH axles. Can you believe this?[​IMG]
    Now for my question. How do I tell it's really a D60? The only thing I noticed is the thick hubs sticking out of the front wheels. While my 10 bolt are about 3.5" in diameter, those were almost 5". Is this a good sign? BTW it had Spicer hubs which looked very tough.
    What else should I look to make sure its really a D60? Thanks!!
    <font color=purple>//////
    <a target="_blank" href=http://blazer79.freeyellow.com>blazer79.freeyellow.com</a></font color=purple><font color=black>
    Soon a 454 K5!!</font color=black>
  2. tRustyK5
    Jul 23, 2000
    36,188
    1,396
    E-town baby!
    Check the steering arm on the drivers side...is it held on with 3 studs? If it is then it is a D44 or 10 bolt. The D60 uses king pins instead of ball joints and the steering arm is held with 4 bolts.
    I'd guess it was a 3/4 ton Sub and it's a D44, but you never know what someone may have swapped in. Good luck!
    Rene
    <a target="_blank" href=http://coloradok5.com/gallery/project_T2> tRusty pics...</a>
  3. Blazer79
    1,816
    Thanks for that info. I think we're talking about a D44 then. Is this still good? or should I pass on these? From what I've learned, a D44 is practically the same as a 10Bolt, right? Would you go with these axles with a 454?
  4. 8_YOUR_H2
    8_YOUR_H2 1/2 ton status
    Feb 20, 2000
    2,663
    Iowa
    You can build a D44 to put up with some major wheeling. Plus you would have the 8 lug front and rear. But a D44 is not as strong as a D60. If you are going to run a tire bigger than a 33" I would upgrade to chro-mo shafts and CTM U-joints to handle the torque of the big block, maybe get a stronger carrier too like a detroit
  5. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    ctms are not for daily driver duty
    formerly 77chev
    still a jerk though
  6. TorkDSR
    TorkDSR 1/2 ton status
    Sep 1, 2001
    1,258
    bucks co pa
    the d60 is better by about 16.....from what ive heard[​IMG]
    beligerence doesn't justify intelligence.
    <font color=blue>wheelers hate posers.</font color=blue>
    <font color=red>79k15/400/700r4/205/38.5</font color=red>
  7. Corey 78K5
    Corey 78K5 1 ton status
    13,055
    Humboldt County, CA
    Juan,
    An 8 lug 44 will be fine. GM put a lot of 454's in 3/4 ton trucks, and from the way you have always described your wheelin habits I dont see where you would need a D-60. By the way if the Burb is stock it will be a D-44 or 10 bolt they never built a 1 ton burb so a D-60 was never offerd in the Burb's.
    Corey 78K5
    350CI, TH350, 203, Dana 44,12 Bolt, 4"lift, Shackel Flip, Sawsall and 35" BFG's
