Differences between lifts.
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by monte0172, Mar 24, 2003.
  1. monte0172
    monte0172 1/2 ton status
    Sep 16, 2002
    182
    Memphis, TN
    Hey everyone I have decided, after much debating and finally finding an excuse, to lift my blazer. (The left front spring bushing is worn to the point of shifting inside the perch causing sloppy steering!!!) My ultimate goal is to be able to run 38's but still be able play in the mud which is no big deal but i also have friends that do mild rock climbing and such. What im wondering is how much more stuff am i gonna have to change between using a 6" suspension lift and an 8"? I know all the standard stuff like lengthen the driveshafts and drop the transfer case and new steering pitman arm but how drastic is the difference between the two? Anyhelp would be great thanks,
  2. Z3PR
    Z3PR Banned
    Mar 30, 2002
    19,217
    Everywhere
    I've got a 6" lift and am go 38" Ground Hawg radial tires. I'll have to trim my fenders, but that's no big issue. If you're not opposed to triming your fenders, Eith 4" or 6" suspension lift is a good choice.
  3. rebelk5frk
    rebelk5frk 1/2 ton status
    Dec 29, 2001
    815
    Houston, TX
    Drive line angles will be the kicker. with a 6" you're normally ok with some shims on the spring perches.
    With an 8" you're getting into the neighborhood of needing a CV joint rear drive shaft and would be better off relocating the spring perches instead of shims.
  4. monte0172
    Sep 16, 2002
    182
    Memphis, TN
    Thats what I was afraid of. I was leaning tward the 6 for that very reason. I would however like somemore opinions if anyone has any.
