Differences between trucks and blazers
Discussion in 'The Garage' started by cj7jeep81, Dec 4, 2003.
  1. cj7jeep81
    cj7jeep81 1/2 ton status
    Feb 17, 2003
    110
    Indiana
    I tried searching, but no luck. I am wanting to lift my '78 K10 and have been searching here for ideas on lift amount/tire height, etc. Granted this is a K5 site, so most of the info is for K5s. Is there much difference in the suspension, fenders, etc. between a K5 and a K10?
    In other words, if a lift and fender trimming would work for a K5 with certain sized tires, would the results be similar for a K10?
    Thanks in advance.
  2. MTBLAZER89
    MTBLAZER89 3/4 ton status GMOTM Winner
    Aug 14, 2001
    7,272
    237
    Oak Harbor, WA
    exactly the same /forums/images/graemlins/thumb.gif 73-87 pickups and 73-91 Blazers and Subs
  3. OrangeCrushK10
    OrangeCrushK10 1/2 ton status
    Jan 25, 2003
    1,425
    Square State + Suspension Item
    Mechanically they are almost identical. The only real difference is the truck has a slightly longer wheelbase, 3 inches or something like that. And the trucks seem to have gotten slightly beefier parts some years.
    Other than that the differences are mainly cosmetic, and still there's very few. Anything you see on this site should work with the K10.
    That's the great thing about these vehicles, everything is interchangable! /forums/images/graemlins/thumb.gif
  4. shaun
    shaun 1/2 ton status
    Apr 22, 2003
    745
    To add to this post does that mean that a 77 3/4 ton drivetrain will bolt uo underneath a 71 blazer? I hope because I am doing it soon and the easier the better.
    Hope i didnt steal your post
  5. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    Thanks!! That's what I was thinking, but wanted to make sure. seventyk5, you didn't steal my post, I found out what I wanted to know! Hopefully someone can answer your question, as I don't know.
  6. Sandman
    Sandman 3/4 ton status Author
    Apr 15, 2002
    5,653
    Pocatello, ID
    I think the rear spring perches are different. Narrower or something.
  7. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    It's my understanding that the 1-ton stuff is a direct bolt up to the Gen 1 K5s; however, the 3/4 ton stuff has wider spring perches. That's not to say that you can't grind em off and well new ones on.
  8. shaun
    Apr 22, 2003
    745
    thanks
  9. Beast388
    Beast388 1/2 ton status
    Nov 6, 2001
    3,039
    Clinton, IA USA
    It almost bolts up. /forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif I did almost exactly the same thing, except I have a '71 Suburban. You will need to move the rear spring perches. The '77 14BFF will have perches that are 42.5" apart (center to center). You will need to make them 40" apart. You will also need to move the shock mounts so you can bolt up the shocks. /forums/images/graemlins/thumb.gif
  10. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    I've got a /forums/images/graemlins/truck.gif and now I'm looking for a /forums/images/graemlins/k5.gif Not everyone here has /forums/images/graemlins/k5.gif.
  11. shaun
    Apr 22, 2003
    745
    I thought only the 2wd 14b had to be modified. Guess Ill be breaking out the torch, grinder, and welder for this one. Oh well. Maybe ill build my cage while I have them all out.
  12. Beast388
    Nov 6, 2001
    3,039
    Clinton, IA USA
    14BFF 3/4 ton 2wd & 4wd spacing: 42.5"
    14BFF one ton 2wd & 4wd spacing: 40.5"
    Your '71 4wd spacing: 40.0"
    /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif /forums/images/graemlins/thumb.gif
  13. 75-K5
    75-K5 3/4 ton status
    Apr 28, 2002
    5,353
    Anderson, Indiana
    Where in Indiana are you? There are several of us Hoosiers on here now! /forums/images/graemlins/thumb.gif
  14. cj7jeep81
    Feb 17, 2003
    110
    Indiana
    I live in south-eastern Indiana (small town of Osgood). I am about half-way between Indy and Cincy.
  15. k5guyva
    k5guyva 1/2 ton status
    Oct 26, 2003
    165
    Southeast VA
    I started with a /forums/images/graemlins/truck.gif and now I have 2 /forums/images/graemlins/k5.gif. Be careful, they multiply!
