Differences in clutches/flywheels between years...
Discussion in 'The Garage' started by Poohbair, Apr 28, 2005.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    I took the old motor out of the K5, and I am putting in an 87 motor... so the flywheels are different. New flywheel should be here tomarrow, but I am wondering if my clutch that I took out will work w/ the new flywheel? Is the mounting bolt pattern for the clutch the same? Thickness the same? Hope so, or I will have to order a new clutch too... :crazy:
  2. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Well if the pressure plate bolts line up, then I think that the clutch disc and all will work. I don't know for sure whether or not it will work, never had anything that new. :blush: May just have to wait and see, or find a good parts store to check the interchangeability of it.
