Differencial Questions
Discussion in 'The Garage' started by ron_mac01, Dec 7, 2005.
  1. ron_mac01
    ron_mac01 Registered Member
    Sep 26, 2005
    17
    ATL,GA
    If your differencial is going bad would that cause the car to grind or pull funny on lift off in first on an automatic or would that cause your flywheel to crack in the middle were it bolt up
  2. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    YES
    It could. if the diff was jammed still, and you had more HP than a lawn mower:doah:
  3. neverendingproject
    neverendingproject 1/2 ton status
    Jul 24, 2005
    1,637
    Tulsa, OK
    I almost went into a siezure when i saw all that big print :yikes: :yikes: :yikes:
  4. colbystephens
    colbystephens 1 ton status GMOTM Winner
    Feb 24, 2005
    10,924
    20
    Oregon
    yeah, pretty sure that sent me through the same thing.
  5. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    What kind of differential ? Open , or a factory limited slip or Gov Loc ?
    You need to pull the cover and look at it before your left stranded because it broke . It may be an easier to fix if its open and you caught it in time .
  6. ron_mac01
    Sep 26, 2005
    17
    ATL,GA
    reply
    it is factory
