different 205 adaptor *DELETED*
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by RUSS84K5, May 31, 2001.
  1. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Post deleted by RUSS84K5
  2. 72GMCJIMMY
    72GMCJIMMY 1/2 ton status
    Mar 17, 2001
    142
    Re: different 205 adaptor
    You may have a divorced unit.
  3. u2slow
    u2slow 1/2 ton status
    May 9, 2001
    2,217
    BC Canada
    Is the adapter attached to the NP205 now? Are you sure its an NP205?
    If the adapter is not fitting the NP205, it could be for an NP203. Some 73-75 Blazer/Jimmy's had the 4-speed and full-time t-case.
  4. RUSS84K5
    Jan 9, 2001
    172
    NEW HAMSHIRE
    The adaptor is on the 205. it is as long a SM 465 adaptor but dosn't have the two machined circles on the front face of the adaptor that act as bearing retainers for the two sm 465 upper and lower bearings.
    Russ V
