DIFFERENT 205 ADAPTOR
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by RUSS84K5, May 31, 2001.
  1. RUSS84K5
    RUSS84K5 1/2 ton status
    Jan 9, 2001
    172
    NEW HAMSHIRE
    Hi,
    I have a np 205. It is a 10 spline input shaft for a manual.
    My confustion is this, The adaptor dosen't have the hourglass/race track bolt pattern on the front face. It is pretty much circular and has a raised bevaled ring around the opening.
    Is this possibly for a SM420?, or those weak three speeds that some K5s had? any info would help. Thanks
    Russ V
  2. Donovan
    Donovan 1/2 ton status
    524
    Arvada, CO
    No that is a late model 205. Post1980 I think that is the year they changed to that style. If that is not right someone tell us what year they did change? My 1986 1 ton dually has the same pattern and it is a fixed yoke. Is yours a fixed yoke?
    Donovan
    <A target="_blank" HREF=http://www.rustbucket.coloradok5.com>http://www.rustbucket.coloradok5.com</A>
    Bigger is Better
  3. pcorssmit
    pcorssmit 1/2 ton status
    Jan 2, 2001
    1,346
    Denver, CO
    Not positive what year, but shouldn't it have 32 splines if it's a late model?
    Pete
    '83 K5, 350 TBI (ex 6.2), 700R4, NP208, Dana 60/14 bolt, 4.56s, Detroits, 3" lift, 15-39.5x15 TSLs
    '97 Dodge 2500 4x4 CC LB Sport, Cummins 5 spd
  4. RUSS84K5
    Jan 9, 2001
    172
    NEW HAMSHIRE
    it has the 10 spline for a manual, the guy I bought it from said he pulled it from a early 70s K5. I'll try to get a picture of it.
    Thanks guys
    Russ V
  5. michaelm
    michaelm 1/2 ton status
    Feb 2, 2001
    872
    sounds like a mix'n'match
    10 spline input gear in a late 80s one ton case
    should have the new 32 like was previously stated
    betcha u2slow could hepl with that
