different arm from a 4-6in lift?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 1990K5, May 24, 2001.
  1. 1990K5
    1990K5 1/2 ton status
    Nov 6, 2000
    460
    LITTLETON CO.
    i just went from 4in springs to 6in springs in front, i had a arm for a four in lift but now its putting my link at a decent angle and i notice more bump steer, all ive seen advertised is an arm for a 4or6in lift. does anyone know where i can get one specificly for a 6in lift? thx--j.c.
  2. SAVAGE1
    SAVAGE1 1/2 ton status
    May 22, 2000
    1,104
    BAY AREA, CA
    From what I under stand, most raised steering arms are supposed to work for 4"-6" lifts. I have a 6" lift on mine and to correct the steering I used a 4" steering arm along with a 2" adjustable pitman arm (drag link). Steers just like it was stock. I believe Superlift makes the arm and it goes for $130 if I can remember. Hope this helps.
    Rod
    [image]http://www.pirate4x4.com/ubb/smilies/beer.gif[/image]<A target="_blank" HREF=http://www.savage1.coloradok5.com>http://www.savage1.coloradok5.com</A>
  3. Emmettology 101
    May 9, 2000
    8,126
    FL
    You could get the 2" drop draglink to go along with your 4" arm to get 6".
    <font color=green>MIKE</font color=green>
    <A target="_blank" HREF=http://emmett.coloradok5.com>http://emmett.coloradok5.com</A>
  4. BadDog
    Feb 24, 2001
    7,777
    11
    Phoenix, AZ
    Actually, a dropped drag link only corrects the joint end alignment. It will not help bump steer since the radius and angle between the pivot points (the rod ends) has not changed. A 2" dropped pitman with a 4" raised arm would fix both the joint angles AND help eliminate most of the bump steer. However, on a flexy suspension, even that is not going to stop it completely, only a x-over can truly fix it...
    Bad Dog
    85 K30 CUCV, 350 TBI, TH400, NP205, D60/C14, 4.56 Locked
    Soon: 4" lift, 40" tires, massive cutting, shorter wb and rear overhang.
