Different headers/manifolds on aftermarket heads???
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by tj_k5, Apr 5, 2004.
  1. tj_k5
    tj_k5 Registered Member
    May 31, 2003
    52
    South Jersey
    OK, so after spitting a valve into my piston, it was time to build a new engine. I picked up a pre-87 350 and stroked it to a 383 and put Dart 2 angle plug heads. Being that I just slapped brand new custom exhaust on my K5, I wanted to use my old engine's manifolds.
    So I go to slap the manifolds on and the stock 350 ones wont fit!?! The new heads have the exhaust ports too close together or far away (I can't remember which). Anybody have experience with this? Will I be able to buy a set of headers that will bolt right on? Thanks ahead of time for your help!
  2. Topdown
    Topdown 1/2 ton status
    Nov 26, 2002
    2,598
    Vancouver, Washington, U.S.A
    I had a set of angle plug heads on my 1972... there are very few headers that will fit with them... Hooker makes a set, I got mine for $110.00, but I believe you can use the early stock ram-horn exhaust with them also.
    -Ryan
  3. Smitty
    Smitty 1/2 ton status
    Sep 1, 2000
    999
    Crestview, FL
    I haven't ever run into the problem you describe. Angle plug heads can be a pain. I've got a set of Edelbrock angle plugs and ended up going with a set of Thorley's and using a shorter plug to get the needed clearance. Let us know how this one plays out.
