Different size backing plates
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Impex, May 8, 2002.
  1. Impex
    Impex 1/2 ton status
    469
    Chandler, AZ
    i was calling a few junkyards here locally (for parts for a 8lug conv.) and this one guy said that he has some backing plates but there the really thick ones? what does he mean by that, dosent sound good for me cause i will be running 15" wheels and have to grind anyway and don't want to grind more that i have to.
  2. arq
    arq 1/2 ton status
    Jan 17, 2001
    2,017
    Imperial Valley/Maricopa
    you can kinda hammer the back plate down instead of grinding it, then grind a bit where the caliper makes contact with it. you'll know what i mean when you start to grind.
    ARQ.
  3. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    I think what he must mean by "thick one" is the one where the caliper mount/dust shield is all one piece of 1/4" steel. That is the one I have and I did the "beat it w/ a BFH till the wheel fits" trick. I am running 15" rims w/ 3.5" backspacing and had to do very little grinding of the backing plate.
  4. Impex
    469
    Chandler, AZ
    thanks for the replies, yeah i figured thats what he ment, the thick part was the caliper support, once i get it all put together ill have to try that hammer trick.
  5. ChevBlazin
    ChevBlazin 1/2 ton status
    Feb 4, 2002
    332
    St. Paul area, Minnesota
    The front axle I jsut got to put in my truck has those real thick ones too. 10 bolt out of a 79 1/2 ton. the backing plates on my stock 86 axle are so thin there are holes rusted thru them.
