Different Size Tires...
Discussion in 'The Garage' started by Capman2k, Sep 26, 2005.
  1. Capman2k
    Capman2k 3/4 ton status
    Jun 22, 2001
    5,070
    dg
    Okie dokie... Today, I noticed that my right front tire, which has been very worn out for a while, was worn to the point that the threads underneath were showing :eek1:
    SO, I whipped out the jack and threw on my spare tire... I'm kind of on the broke side, or I would just go out and buy another tire... Anywho, I noticed that my spare tire is not only a different brand, but a different size...
    Whatever numbnuts before me decided to put smaller tires on the Jeep (215's) and didn't bother to replace the spare also... So I have three 215's and a 225... I took it to Ray to get the lugnuts torqued properly, and he said to simply not put my Jeep into 4wd... Problem is, it has the full-time 4x4... He just laughed and that was that... What can I expect to break in the near future with my different size tires? :confused:
  2. fatbob
    fatbob 1/2 ton status
    Jul 3, 2003
    420
    Phoenix, Az
    Go here ,http://4lo.com/calc/gearmetric.htm
    and compare the two tire sizes. I found only about .5 inch difference if the tires are both xxx/70r15.
    You also dont say if you have lockers or not, so without more info, I would suggest running the different sized tires on the front axle. I don't think you will have any problems at all with it on the front, unlocked
    good luck
    Bob
  3. trailblazr81
    trailblazr81 1/2 ton status
    May 27, 2005
    931
    Hollister, CA
    I think its close enough you'll be OK... run it in front. What vehicle is this? Is it a standard full time 4 wheel drive or that new fancy "thing thinks its smarter than me" and detects what it thinks is wheel spin and routes power to a different whel and/or applies brakes? :doah:
    I hate technology... well except for limited slips that turn into lockers with a flip of a switch...
  4. mikey_d05
    mikey_d05 1 ton status GMOTM Winner
    Nov 23, 2004
    10,453
    Minnesota
    If it's plain full time 4wd you should be alright. If it's Quadratrac or their fancy automatic limited slip/braking thingy you might have problems.
  5. Capman2k
    Jun 22, 2001
    5,070
    dg
    It's the Quadratrac... I assume I don't have lockers since this Jeep is completely stock other than the midget tires someone put on there :doah:
    My understanding of Quadratrac is it's one of those "thinks it's smarter than me" systems, if I'm not mistaken...
  6. trailblazr81
    May 27, 2005
    931
    Hollister, CA
    I still say it should be OK. If its only a half inch smaller. And if it has full tread while your other tire is worn its pretty close. :wink1:
  7. sweetk30
    Nov 1, 2004
    25,546
    542
    horseheads , ny 14845
    if open diffs then o.k. just will steer funny on the front.
