Differential Capacity????
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BlazinBaldy, Jan 14, 2003.
  1. BlazinBaldy
    BlazinBaldy Registered Member
    Jun 10, 2002
    10
    Pismo Beach, CA
    I have a 1988 stock blazer, and I just wanted to know whats the best weight oil 90 or 85/140 and how much? /forums/images/graemlins/k5.gif
  2. 89GMCSuburban
    89GMCSuburban 1/2 ton status
    Nov 15, 2001
    3,005
    Thornton, CO
    Coastal 80w90 is good stuff...depends on axle, but I'd buy 3 quarts per axle. Undo the fill plug, fill till it starts coming out...
  3. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I would buy 3 per axle to be on the safe side but my 12b and d44 only took 2.5 each.
    As for weight, depends on your axles and where you live.
    In cold weather you need hinner, but if you have a worn axle with big tolerances, if it makes noises, I would go with thicker.
    The multi grades are usually synthetic so they are better as well as more $$$
  4. Highlander
    Highlander 1/2 ton status
    Nov 25, 2000
    1,204
    Lakewood Colo
    You should get 3qt. per axle. As for what weight I run 75/90 but like somebody else said if you have a lot of miles you could run 85/140 or a 75/140
    As to what I think is the best Oil go web page
    well that didn't work the way I wanted it to /forums/images/graemlins/rotfl.gif
    Oh well that Gear oil will help you the most in the long run.
    Eric
