Differential Cover Gasket-Sealant?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by k20, Dec 17, 2002.
  1. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ok, today when i get home im going to change the front diff oil, since yesterday i noticed it looks like very light chocolate milk. Anyway, my question is, when i go to reinstall the cover w/ the new gasket, do i use some type of sealant? What kind do you recommend? Also if i have to use some, where do i put it? on both sides of the gasket? just on the cover side? just on the diff. side? Thanks y'all.
  2. outlaw612
    outlaw612 1/2 ton status
    Feb 11, 2001
    2,342
    Springfield, Illinois
    I usually just use silicone. If I do use a gasket, I put the silicone on both sides.
  3. SkulzNBonz
    SkulzNBonz 1/2 ton status
    Feb 20, 2002
    4,522
    OKC, Oklahoma
    I just use Permatex red RTV, no gasket. Put it on the cover, let it set up for about 15 minutes, then slap it on. No leaks whatsoever.
    John
  4. bigmack
    bigmack 1/2 ton status
    Jan 3, 2002
    478
    Tennessee
    I never use a gasket. I use whatever Permatex I have, blue, red, black, whatever. I've been doing this for years and never had a problem. Just make sure both the cover and diff mounting surfaces are clean and dry before you apply the Permatex.
  5. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Another vote for no gasket. I've never used them and have never had a leak. A thin bead of RTV, let it skin, then slap the cover on. No fuss no muss. </font color>
  6. Seventy4Blazer
    Seventy4Blazer 3/4 ton status
    Apr 21, 2001
    5,634
    Escondido, CA
    Same here.
    wux gud. /forums/images/graemlins/thumb.gif /forums/images/graemlins/pimp1.gif
    Grant
  7. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    I haven't bought a diff cover gasket in my life. /forums/images/graemlins/thumb.gif RTV seals it up so well that I've never had so much as a single drop leak out. /forums/images/graemlins/cool.gif Just don't go crazy with the RTV, it just takes a very thin layer to seal it up.
  8. BurbLover
    BurbLover 1/2 ton status
    Jul 31, 2001
    3,060
    SW Missouri
    Once again, I vote for no gasket!! If you have a gasket &amp; you hit an object, it pushes the metal into the gasket &amp; will leak around it. The only RTV I like to use is the black. It works on ALL occasions, not just some. Anyway, just my $0.02!!!
    /forums/images/graemlins/burb.gif
  9. fortcollinsram
    fortcollinsram 1/2 ton status
    Nov 8, 2001
    2,261
    Fort Collins, CO
    When ever there is just a cover involved, I just use RTV...but if the sealing surface acts as a structural member (bearing retainer or other) I use a gasket and RTV...When I was sealing my adapter between my 465 and 205, I only used RTV at first...big mistake on my part...the adapter wasn't able to seat flat on the seal surface b/c the bearing for the tranny had bottomed out in its retainer groove and was acting as a pivot...as a result of the RTV being too thin, I stripped 4 bolt holes out of the tranny...So with diff covers, PTO covers, etc, I use RTV...but tranny/t-case adapters, tailhousings, etc, I use bioth a gasket and RTV...
    Chris
  10. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    Ok, well i was gonna use a gasket.......but ended up just using the rtv. Now on to the most newb question i can think of, wtf front axle do i have?!?!?!?!?! I always thought it was a 10b, well i bought a 10-bolt gasket. Nope, not it, took it back, thinkin, ah, well got a D44 then, got a D44 gasket, nope, said forget it, slapped some rtv on it, and called it good........now.......*praying d60* what front axle do i have? theres only one or two pics below, but a 87, chevy 3/4ton 14SF rear.....
  11. Shaggy
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> Looks like a 10 bolt to me. Definately not a D60, you can tell by the inner u-bolt on the passenger side. There are several versions of the 10 bolt, they probably just gave you the gasket for one of the S-10 or Camaro ones.</font color>
  12. k20
    k20 3/4 ton status
    Sep 9, 2001
    5,068
    Mineral Springs, NC
    well, if the guy did, hes a moron. He asked what yr it was out of and what it was out of. Ah, pep-boys sucks. The guy was being a jerk lol. I was still talkin and hes like awe, we cant get u an axle here. Ok, well i was still talking but anyway.
  13. m j
    m j 1/2 ton status
    Dec 28, 2001
    4,606
    too bad on the no gasket
    if you play in water, and you do if you had choco milk, you will most likely tire of scraping the silly putty off when a gasket would just peel off nice n clean for oil changes.
  14. Pure Insanity
    Pure Insanity 1/2 ton status
    Mar 17, 2001
    4,579
    Dade City, Florida
    Im another of the no gasket guys. I use Right Stuff. I dont recall who makes it, maybe Loc-Tite. This stuff is unreal. When it dries its MUCH more firm than any other I have used. The cover wont just pop off when you take the bolts off, it actually takes a bit of persuading. Doesnt stay gooey feeling. Never had a leak, and scrapes right off no problem. /forums/images/graemlins/thumb.gif
