differential cover
Discussion in '1969-1972 K5 Blazer | Truck | Suburban' started by bdkmiller, Oct 21, 2002.
  1. bdkmiller
    bdkmiller Registered Member
    Jul 31, 2002
    42
    NH
    I just got a diff cover from LMC Trucks. I was really disappointed to find that it does not have a filler hole or plug. I suppose I am supposed to drill it out & weld a bolt to it. Is this correct? Also is there a preferable way to do this. And how do I know where to put it, just approximate it based on my old cover?
    Thanks,
    Brian
  2. bouncytruck
    bouncytruck 1/2 ton status
    Oct 11, 2001
    858
    Bothell, WA
    Could you put a transmission pan plug into it? Is it a crome cover? I'd return the cover and get one from Summit.
  3. bdkmiller
    Jul 31, 2002
    42
    NH
    Maybe I should have got it from Summit. I thought about it but LMC's were very cheap, just about $40 including shipping. Saddly, the only reason I bought it was to get a decent filler hole. My current diff cover has a tiny filler hole & filling it is horrible. Plus it takes way too long. It is just regular sheet metal, no chrome. I am going to look into putting a tranny filler plug in it.
    Thanks,
    Brian
  4. Blazer1970
    Blazer1970 1/2 ton status
    1,600
    Old Mission, MI
    None of the normal differentials used in Chevys have a filler hole in the cover. The filler hole is normally in the differential housing.
  5. Greg72
    Mar 5, 2001
    15,683
    1,392
    642 Days to BB2018
    Tim,
    Are you sure about that...? /forums/images/graemlins/crazy.gif
    Both my D44 and D60 have plugs in the cover to fill them. However on the REAR axles (12-Bolt and 14-Bolt)...my experience has been similar to what you describe, and the filler plug is in the pumpkin itself and NOT the cover....
  6. Burt4x4
    Burt4x4 3/4 ton status
    6,854
    California (Modesto area)
    ahhhh, the 12bolt I destroyed had a filler hole in the diff cover. My D44 front and D60 rear both have filer holes in the diff cover. I didn't think there was any other way to fill the diff??? Oh and by the way my opinion is that LMC is THE highest priced of all the resto places. try www.chevyduty.com or www.brotherstrucks.com next time... my .02c
  7. TONYP
    TONYP 1/2 ton status
    Aug 13, 2002
    2,116
    so cal
    This place has some good deals on parts.
    Truckshop
