Differential Gear Ratio change question - do I need a new carrier???
Discussion in 'The Garage' started by captaininsano, Jun 7, 2005.
  1. captaininsano
    captaininsano 1/2 ton status
    May 4, 2004
    233
    Bay Area, CA
    I was looking into changing my gear ratio to 4.88 gears on my rig, I have a 10 bolt and a 12 bolt (ya ya I can't afford a dana60 so save it if that is your response). Now that we are past that, I saw anything past a 3.73 requires a new carrier? Is this correct? I believe highly my 78 k5 has 3.08 gears, it was originally an automatic/np203 truck. Now has a SM465/np205 thanks to me. If I need new carriers that sucks. Any info is greatly appreciated! :D
  2. captaininsano
    May 4, 2004
    233
    Bay Area, CA
    Also, I have never setup gears, but want to try. What do I need to know, any special advise or experiences?
  3. pauly383
    Jul 22, 2001
    16,217
    Mesa , Arizona USA
    As far as I know , 10 bolt 8.5 has one carrier break . 12 bolts though have 3 carrier breaks . You actually have 3.08 front and 3.07 rear . You need a 3.73 and numerically higher carrier ( lower gears ) for your 12 bolt .
  4. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    The 10 bolt has 2 carriers, one is 2.56 only and the other does 2.73-5.57's
    The 12 bolt however has 3 carrier breaks and are 2.73 only, 3.07-3.42, 3.73-4.56's
    So, you will need a carrier for the 12 bolt but not on the 10 bolt.
  5. sebban
    sebban Registered Member
    Jan 18, 2005
    63
    sweden
    Can you get 4.88 gears on a 10/12 bolt setup? (I have the exact same setup, and plans.. ;))
    As far as I could gather, you could only go to 4.56 gears.
    Please enlighten me! :cool1:
  6. 4X4HIGH
    Dec 14, 2001
    22,063
    70
    Pleasanton, CA.
    You can get 4.88's for a 10 bolt but the deepest gears for a 12 bolt are 4.56's
  7. captaininsano
    May 4, 2004
    233
    Bay Area, CA
    Well 4.56 would be nice too, anythings better than what I have.
    As for setting them up, should I attempt it or just have a shop do it? I am pretty damn mechanically inclined, but at the same time gear sets are pricey and destroying them would really suck. How difficult is the swap?
    I think maybe I will just try to find a 4.56 12 bolt in a junk yard. I guess another option is a spool, but I drive it on the street still, so not so much an option.
  8. captaininsano
    May 4, 2004
    233
    Bay Area, CA
    GM 12 BOLT 8.875" TRUCK RING & PINIONS
    PART # TEETH RATIO
    14022236 40-13 3.08
    14022237 41-12 3.42
    471879 41-11 3.73
    471879X* 41-11 3.73 THICK
    474014 37-09 4.11
    474014X* 37-09 4.11 THICK
    GM12/456 41-09 4.56
    (*these thick gears are designed to fit a 2.76 thru 3.42 carrier)
    I just found this on http://www.usgear.com/tl/gm2.htm So if I understand this correctly I could go with 4.11 without having to change the carrier? The 3.08 carrier would work with the 4.11 thick gears? If this is the case I might just go with this until getting a 14FF.
    I am trying to get more bang out of the 1/2 ton stuff for now until I can afford the 1 ton stuff, but at the same time, I don't want to invest the duckets in the 1/2 ton junk. If the 1/2 ton gear can last me about a year I will be cool I think..
  9. sebban
    Jan 18, 2005
    63
    sweden
    Dito!!!! :P
    So 4.11 it looks like for me too, but I need to save up some cash first.
