Differential question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by James, Jul 6, 2000.
  1. James
    James 1/2 ton status
    Jun 22, 2000
    179
    Castaic, Ca
    Just yanked my np203 tcase and driveshafts replacing seals due to leaking and replacing ujoints. Noticed 2 things not real sure of. 1)how much play should there be in the front differental. When I grab the flange and move from left to right there is a good 1/2 inch of play. Is this acceptable or not? 2)Can the transmission leak fluid from anywhere other than the rear seal or the trans pan? It seems as though fluid is leaking well in front of the trans pan furthur up around the torque converter. Is this possible?. I appreciate the slightest bit of info as I am farely new to mechanics. np203 and th350
    James
  2. 72junker
    72junker Registered Member
    Apr 23, 2000
    66
    atlanta (body) colorado (soul)
    There's s front seal on a tranny around the shaft that the torque converter sits on. Changing it is easy... Getting to it requires dropping the tranny.
  3. tom
    tom 1/2 ton status
    May 20, 2000
    157
    So. Cal
    There is also an o-ring around the cover of one of the actuator pistons. It is easy to change, so make sure it isn't leaking before going deeper.
  4. MudFrog
    MudFrog 1/2 ton status
    Feb 23, 2000
    3,236
    Daleville, Va
    I would think with a half an inch of play your gonna have to replace the ujoint soon anyway, so why not do it now before it's on the side of the road somewhere.
    89 K5 Silverado
