Differential rebuild question
Discussion in 'The Garage' started by berg76, Jun 5, 2004.
  1. berg76
    berg76 1/2 ton status
    Nov 4, 2002
    238
    St. Louis, Missouri
    I need to replace my carrier/pinion bearings in my 14BFF. I am not replacing the ring and pinion unless I find damage when I tear it apart. I have all new bearings, crush sleave, seal and pinion nut. My question is will I need pinion shims if I reuse the stock ring and pinoin??? /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/thumb.gif
  2. SCJimmy
    SCJimmy 1/2 ton status
    Mar 7, 2003
    406
    Simpsonville, South Carolina
    I'll take a shot at it and say no, you'll be fine. Just check the pattern. I rebuilt mine with the original R&P. All new bearings, races, pinion and support bearings, and crush sleeve. Reinstalled the original pinion shim, got the pattern right, and locked her down tite. It's been 3500 miles, and no problems yet.
    Just my .02... /forums/images/graemlins/wink.gif
    Byron
  3. K5MONSTERCHEV
    K5MONSTERCHEV 1/2 ton status
    Jan 27, 2003
    3,254
    Castro Valley, CA
    NO, just do a pattern check and backlash. When you put it all back together, nothing should change.
