Differential Vent Question...
Discussion in 'The Garage' started by IGOR, Aug 12, 2003.
  1. IGOR
    IGOR 1/2 ton status Premium Member
    May 16, 2000
    2,303
    19
    Damascus, OR
    My parts counter guy looked at me funny when I asked him for a differential vent - what are you guys using for vents for your axles?
    I'm planning to raise my vents up as high as I can (to keep water out) - but then what do I cap them with?
  2. Hossbaby50
    Hossbaby50 3/4 ton status
    Sep 1, 2001
    8,972
    Peoria, AZ
    Your diff should have the vent nipple coming out of the top somewhere. Then I run a piece of fuel line hose up to the bottom of the body to the factory vent tube clamp, and I think the tube has the stock valve in the top. I think the valve is a 1 way valve so that air will come out but water and stuff won't go in.
  3. IGOR
    May 16, 2000
    2,303
    19
    Damascus, OR
    Yeah, I have the nipple on the axle side - but my one-way valves are "always" valves now - the top half was gone... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
  4. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    You can try a few things...
    A cheep plastic fuel filter or a PCV valve (acts as a roll over valve too).
  5. Don
    Don 1/2 ton status
    May 30, 2002
    1,778
    Spokane Washington
    It also depend's on how deep of h20 you plan on getting into. If forging a river, or stream is on the list, then the higher the valve the better, like up on the firewall somewhere. /forums/images/graemlins/eek.gif
