Differential
Discussion in 'The Garage' started by TBlaz8, Feb 11, 2007.
  1. TBlaz8
    TBlaz8 Registered Member
    Feb 9, 2007
    17
    Orinda, CA
    i am buying a differential rebuild kit for my full sieze jimmy. wat is the difference between a 28 spline and a 30 spline? what should i get for my solid axel jimmy?
  2. big83chevy4x4
    big83chevy4x4 3/4 ton status
    Mar 22, 2002
    6,587
    Sheridan, Michigan
    it refers to the axle spline count. if you change it, you need new axle shafts. if you let us know what year your blazer is, we can tell you what spline shafts it should have if they are original.
  3. TBlaz8
    Feb 9, 2007
    17
    Orinda, CA
    i have a 1989 GMC Jimmy full sieze, stock axel.
  4. txfiremank5
    txfiremank5 1/2 ton status
    Jul 6, 2004
    3,105
    San Antonio, TX.
    That would be a 30 spline.
  5. goldwing2000
    goldwing2000 Guest
    Correction: That SHOULD be a 30-spline.
    My '89 had 28-spline (which I didn't realize until after I ordered the lock-rite, of course).
    '88/'89 Blazers and Burbs are the bastard children of the parts bin. All the C/K pickups got the new, gee-whizzy parts while the R/V crowd made due with leftovers.
    Only way to know for sure is to pull the cover and count them.
    Are you rebuilding the front or rear axle?
  6. txfiremank5
    Jul 6, 2004
    3,105
    San Antonio, TX.
    Good point, better to be sure, than to go on "what's supposed to be in there". ;)
