Differnces in 4l80e
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by PsRumors, Feb 4, 2007.
  1. PsRumors
    PsRumors 1/2 ton status
    Nov 11, 2006
    626
    Cartersville, GA
    I can't find it but I am sure I once read that there are two version of the 4l80e in the '90s. What are they and which is better or prefered?
  2. BulldogK5
    BulldogK5 1/2 ton status GMOTM Winner
    Sep 19, 2002
    4,158
    Brandon, MS
    There is a slight case change I think in '94. Also, the ones backing a diesel have a seperate computer to run than the TBI harness in the gas version. Sorry if this does not help, wasn't sure what you were looking for.
  3. sweetk30
    Nov 1, 2004
    25,552
    546
    horseheads , ny 14845
    91-93 bad harness in valve body easy update tho.
    and 96-97ish moved 1 cooler line to rear of tranny case for better flow of hot fluid to cooler.
  4. PsRumors
    Nov 11, 2006
    626
    Cartersville, GA
    Great. Thanks for the info.
  5. NateInChandler
    NateInChandler 1/2 ton status
    Apr 23, 2006
    418
    Chandler, AZ
    make sure you match the case's up for what vehicle it is, i made this honest mistake about a week ago after having it all rebuilt and everything and bolted to the block... bad carma i guess... your looking at the mounts for your eutral safety switch aka manual lever position sensor and the mounts for the shifter bracket.. also make sure of cooler lines and stuff like that cause there is two different ones..... Nate
