Dilema w/ installing 52's in front...
Discussion in 'The Garage' started by Poohbair, Jun 6, 2004.
  1. Poohbair
    Poohbair 1/2 ton status
    Jan 30, 2003
    2,139
    Ellensburg, WA
    Dilema w/ installing 52\'s in front...
    So this is what I am pondering w/ the front 52's. If you move the front hangar forward 4", then you also move the front axle forward 2"...which is what I want. Problem is that this also leaves you w/ a piss poor shackle angle unless you also move the shackle mount forward 2".
    However, if you only move the front hangers forward 2", you are left w/ a good shackle angle, but the front end stays in the stock location...
    I have tire/firewall clearance issues so I would really like to get the frontend forward 2", but it looks like a big PITA to move the shacklemouns forward on the frame... Does anyone else have an option here w/o buying a zero rate... I am way to cheap for that!! /forums/images/graemlins/rotfl.gif /forums/images/graemlins/rotfl.gif
    Let me know what you guys think...
  2. sled_dog
    sled_dog 1 ton status
    Sep 3, 2002
    16,870
    Austin, TX
    Re: Dilema w/ installing 52\'s in front...
    drill your spring perches and move the axle 1.5" forward that way. Gives you a better approach angle and your better firewall clearance.
  3. 84_Chevy_K10
    84_Chevy_K10 Banned
    17,669
    IL, USA
    Or just move your shackle mounts. See the pics in my webshots under the album "Got shackle angle?" for details. /forums/images/graemlins/thumb.gif
  4. Zeus33rd
    Mar 14, 2002
    7,324
    9
    Grass Valley, CA
    Moving the shackle mount forward is simple. Unbolt it, drill two holes for the bolts, cut a larger hole for the middle of the mount, and blt it back on. 45 minutes per side would be my guess. I haven't done it yet, but it's on the list. Hmm...Maybe I'll just get out there and do it now...heh /forums/images/graemlins/pimp1.gif
  5. zcarczar
    zcarczar 1/2 ton status
    Feb 10, 2002
    2,495
    Apple Valley California
    Run 56's like im going to.
  6. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    always got to start crap don't you? I still say drill the spring perches and only move the mount 2" forward. Will create a better approach angle. If you move the front mount 4" forward your approach will be worse than it likely is now.
  7. seattlek5
    seattlek5 1/2 ton status
    Feb 23, 2001
    311
    ...with one hand on the bender.
    Check your e-mail pooh...the angle is not as bad as you think.
  8. zcarczar
    Feb 10, 2002
    2,495
    Not really, Im just offering up another approach. I like to say that im thinking outside the box.
    On the approach angle thing, I hit my front end MORE with the mounts in the stock spot and the axle in the stock spot than I do now. Actually I dont think the approach angle changes, if anything it gets a tad bit better since the frame is curving up where the mounts go. And my shackle angle is semi-decent with the 52's up front, If I actually made some longer shackles I would have more travel up front than I can use. Hell I already have enough travel, my 14" Travel Race runners are all used up.
  9. sled_dog
    Sep 3, 2002
    16,870
    Austin, TX
    I was joking about starting stuff /forums/images/graemlins/wink.gif as far as approach angle, I was under the impression 52s hurt approach a little. Either way I say drill the spring perches. Better approach angle is always a good thing. I will do this whenever I get the energy to unbolt the damn axle and do it.
