Dim Headlights
Discussion in '1982-Present GM Diesel' started by AzzKicker, Mar 3, 2003.
  1. AzzKicker
    AzzKicker 1/2 ton status
    Jul 28, 2002
    265
    Edinburg, Tx
    Whats a cause of dim headlights. My lights are pretty clean and before I spend money on headlights I want to make sure its not the Alternator.
    Althoughf or Some Odd reason if I'm driving down teh road, my volt meter shows between 14-16volts. mostly 14.
    You think my Alternator is bad. If so, how much do they run for a 6.2J code engine.
  2. rugger03
    rugger03 1/2 ton status
    May 14, 2000
    829
    around
    GM used very small gauge wire for the headlight, if you got the time and inclination i would replace the wires with 10 gauge and install relays. that will probally take care of your dim bulbs.
  3. alec78
    alec78 1/2 ton status
    Aug 5, 2002
    358
    Washington
    Also check the body ground! Make sure is is tight and clean. Follow the ground wire from the passanger headlight to the body. Usually a rather rusty spot. If you can check with an ohm meter.
  4. Espen88k5
    Espen88k5 1/2 ton status
    Feb 19, 2000
    981
    Norway
    I second <font color="blue">rugger03 </font> The wires are hopelessly underdimensioned (word?)..friend of mine did this, got instant results by using a rele instead of running all the power thru the switch on your dash...
  5. imiceman44
    imiceman44 1 ton status
    Aug 5, 2002
    15,160
    Sacramento, CA
    I do that to all my cars now.
    It's a trick I learned from all european cars.
    smaller switches better lights.
    /forums/images/graemlins/thumb.gif
  6. AzzKicker
    Jul 28, 2002
    265
    Edinburg, Tx
    Where do I go to get a rele, is there a certain part etc. Where can I find wiring diagrams.
