dimensions on crossover arm
Discussion in 'The Garage' started by DERBINATOR, Mar 5, 2005.
  1. DERBINATOR
    DERBINATOR 1/2 ton status
    Jan 26, 2001
    196
    YANKTON,SD
    Does anybody know how long it is from the center of the kingpin to the draglink hole on a chevy dana 60 crossover arm?
  2. DERBINATOR
    Jan 26, 2001
    196
    YANKTON,SD
    I was just thinking the distance would be the same as my dana 44 crossover arm from balljoint to draglink hole. Right?
  3. NorthWestFab
    NorthWestFab 1/2 ton status
    Jan 11, 2005
    311
    Canada Eh.
    Our new crossover arms are 7" from the center of the kingpin to the draglink hole.
    if you need the knuckle stud pattern, just let me know.
  4. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Got any pics/illustrations of the ones your making? :thinking:
  5. cyclone
    cyclone 1/2 ton status
    Oct 11, 2004
    243
    Sonoma, CA
    RockLogic arm
    my RockLogic D60 crossover arm is 7" from center of cap to TRE hole.
  6. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    Here is a CAD rendering
    That one is the double arm design. We made them to be able to run the tierod on either the front or rear of the axle (which is required for a 52" spring swap or similar), and works with axles heavily relocated, which 95% of the arms out there will NOT let you do. They're Billet 4130. The double arm is cut from a huge block, 14"x4"x2" ! My arm has 3 holes, 1 for the draglink, 1 for the tierod, and 1 for the ram.
    The caps are built in, and designed for factory type studs. The arms include the 5th dedenbear hole. The arms also clear hummer rims with stock backspacing (probably not a feature required for most of our Fullsized rigs). They also have correct steering geometry designed into them.
    They're being prototyped right now, so I don't have any final photos, no do I have a finalized price. It will be highly competitive, and we're going to produce a load of these as soon as we can. So much to make, not enough time in the day!
    -Kyle
    Northwest Fab
  7. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    Oh yeah, and if you want to try your hand at making your own arms:
    The axle is actually at a 8.5* inclination angle not 10. 10*'s will help the joint of your draglink, but won't help your tierod.
  8. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    Very secksy! :pimp:
    Are you going to have a variety of arms or will the one style fit all needs? I know some companies offer with/without Hummer offests, with/without the rear hole etc..
    Also, from the drawing it appears that the forward "branch" of the arm is raised slghtly above the based that touches the knuckle - how much? I've read that if you use a Zero Rate (with forward offset) on the front some arms require a spacer for tie rod clearance, will this lift eleminate this?
    Finally, do you have a rough idea of when you'll be ready to sell them (summer, fall, etc)?
    THANKS for the info and pic!
  9. NorthWestFab
    Jan 11, 2005
    311
    Canada Eh.
    The point where the TRE enters the arm is 1.9" higher than the surface of the knuckle, they're the tallest D60 arms I know of w/o a spacer.
    We're going to do a variety of styles, Single passenger side, double passenger side, single drivers (highsteer addition) etc.
    Although I would recommend getting a double as I found once you decide to change your axle location, you might have to buy new arms :mad:.
    A double arm also gives a great location for a hydro ram.
    The hummer offset actually does help your steering geometry, weather you need the wheel clearance or not. If taking it out means we can offer them a fair bit cheaper, then we will do that.
    Summer is a good conservative estimate. The shops been fondling the drawings for a while, but it keeps getting puched back due to milling adaptors, 1410 yokes etc.
    -Kyle
  10. nvrenuf
    Jan 7, 2002
    13,076
    246
    Mobile, Al.
    EXCELLENT info! For me, the timing on the release date of the arms will probably be just right. Go ahead and get a box ready to ship to the Gulf of Mexico. :D
    Thanks for the tech, Kyle. :thumb:
