dip stick pops out
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by Sparky, Mar 4, 2001.
  1. Sparky
    Sparky 1/2 ton status
    Aug 20, 2000
    423
    San Antonio(summer) Texas A and M (school year)
    What is with my dipstick on my th350? Every time I drive my truck the dipstick pops out a inch or so and spits a little fluid out. I thought it was building pressure because the fluid was too high, but the level is fine hot and cold. Could my filter be a little clogged or something? What causes this? Thanks.
    Sparky
    When all else fails... Check the blinker fluid.
    78 K-5
  2. Triaged
    Triaged 1/2 ton status
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    If your PCV (Positive Crankcase Ventalation) valve is cloged it can cause the preasure to build up and pop the dip stick out. For how cheep and easy the are might as well try it.
  3. Sparky
    Aug 20, 2000
    423
    I'm talking about the tranny dipstick. Can the PCV cause the tranny dipstick to pop out? Its new anyways. Any other suggestions.
    Sparky
    78 K-5
  4. Blue85b
    Blue85b Registered Member
    Mar 5, 2001
    22
    You might want to check the transmission vent. The tube or vent top might be plugged. There is some air in the transmission, so it is normal for pressure inside it to change as the temperature changes
  5. Triaged
    Feb 21, 2001
    3,808
    CA (LA/OC area)
    Sorry I missed the "th" in front of the "350". PCV has nothing to do w/ trans.
  6. mudhog
    Nov 6, 2000
    17,899
    portland oregon
    the dip stick bolts to the bellhousing loosen that bolt and pound it all the way down then re tighten the bolt and see if that helps
    s.smith 77blazer lookin 4 mud [​IMG]
