Dipstick and rear glass on 84 K5?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bajaviking, Jul 9, 2003.
  1. bajaviking
    bajaviking 1/2 ton status
    Apr 10, 2002
    752
    Baja
    I am thinking about buying an 84 Blazer, I can get it for $800, it is in decent shape but needs some TLC.
    The rear glass is broken, does anybody know how much that is and where to get it. Also, the dipstick is on the drivers side, on my 86 it is on the passenger side, what is the difference or is it a 305?
  2. RustBuket
    RustBuket 1/2 ton status
    Feb 21, 2003
    1,618
    Saskatchewan, Canada
    I don't think its a 81-85 305 because mine is an 84 or 85 and the dipstick is on the passenger side.
  3. ramjet gmc
    ramjet gmc CK5 Staff Staff Member Moderator GMOTM Winner
    Dec 19, 2001
    3,370
    Milltown NJ 08850 NJ sucks
    I am thinking Pontiac moter like in the 1970 can someone with more exp take a stab
    and glass any junkyard $50 and you pull it
  4. dyeager535
    26,979
    Probably just an earlier Chev motor. (my '74 350 is DS dipsick FWIW)
    Much more likely thats the case than someone putting in a Non-Chev motor that year.
  5. wa_jeeper
    wa_jeeper Registered Member
    Mar 3, 2003
    85
    Great Lakes, IL
    Hard to say what year it is, the Goodwrench 350 in my 78 K5 is a D/S dipstick (royal pain thanks to the brake booster...)
  6. daimok
    daimok Registered Member
    Jul 18, 2002
    40
    north carolina
    i wouldnt get too scared on the emmisions part. my 83 had alot of missing vaccum hoses and a few other non emission things missing , trick is getting an inspection at the right place and right time.
    never go to a state inspection only shop if they have them in your area. I go with jiffy lube , wait till close to closing in the hottest days around. you can wait in the car and even have it running ( helps with the sniffer ). makes being under the hood for the "mechanic " hot as hell. they want to go home , its hot and most likely ye will get a sticker.
    i renew mine every time i get a set of tires at firestone. you buy $600 - 800 in tires they usually gonna throw in the sticker.
    i kept egr and smog pump , i have headers that have AIR injection , edelbrock carb and vaccum hoses on the charcoal canister that go - no where /forums/images/graemlins/rotfl.gif i swapped out the water neck from the emmision one to a plain one , they dont see the missing hoses so they usually miss that one too
    Its not that i try to defeat to emmissions , i cant get a emmissions diagram from parts book ( says to use sticker under the hood ). havent been able to read it for years and the dealer doessnt stock them.
