dipstick grommet question
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by bee32, Sep 26, 2001.
  1. bee32
    bee32 1/2 ton status
    Aug 6, 2001
    401
    Virginia Beach Va.
    Any one ever replaced a dipstick grommet and not torn it. I have replaced the one in my tranny three times. I have tried putting grease on it and anti seize. Both times it got tore up around the last 1/8 inch inside the tranny and when I am in traffic or hittin it hard for a time in the mud it starts to piss out onto the exhaust pipe statring alot of smoke. It is funny to be at a light when it happens and to look over at the people next to me and then just wave at them. :)
    Brian
    83 K-5 4" on 33's
  2. Burbinator
    Burbinator 1/2 ton status
    Sep 14, 2001
    898
    Tempe, Arizona
    It sounds like you might have something stuck inside the tranny case hole, ripping the grommet as you install it. Just my $0.02.
    - Alan
    '82 K10 Suburban Silverado (AKA U.S.S. Nimitz)
    Always do sober what you said you'd do drunk. That will teach you to keep your mouth shut!
  3. newyorkin
    newyorkin 1 ton status
    May 8, 2001
    16,555
    157
    Los Estados Unitos
    I had a <a target="_blank" href=http://k5.8m.com/dipstick.htm>similar problem</a> once.
    Are you removing the pan when you do this? You should be able to see what the problem is if you have the pan off when you replace the grommet.
    It also sounds like the dipstick or bolt-down tab may be bent and angling the end too much into the grommet when you bolt it down, then maybe hitting the firewall and making it wear out the grommet.
    Ratch
    <a target="_blank" href=http://k5.8m.com>k5.8m.com</a>
    **Ever stop to think... Then forget to start again?**
  4. dyeager535
    26,976
    Are you using the right seal/tube? Both o-rings AND actual grommets were used. One won't work well on the other I'm sure. TH400 I have needed a grommet, not the o-rings the PO tried to use, unsuccessfully.
    Dorian
    My tech/links page: <a target="_blank" href=http://www.dorianyeager.com/index2.html>http://www.dorianyeager.com/index2.html</a>
    No anti-theft measures on your truck? No pity when its stolen
