Dire help needed
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by 83bowtyblazer, Feb 25, 2003.
  1. 83bowtyblazer
    83bowtyblazer 1/2 ton status
    Jul 29, 2001
    132
    Ft. Dix, NJ
    I need some help diagnosing a problem. I have an 83 with a 305. Whe it idles, it sounds perfect, then it knocks a few times, the idle drops, then it picks back up and runs smooth again. It seems like it loads up, drops idle, then it goes back to normal. Any ideas?? I put the stethoscope to the drivers side valve cover and it sounds like it's coming from there. Pushrod?? Rocker arm?? Help!!
  2. TopOff
    TopOff 1/2 ton status
    Jan 16, 2002
    1,760
    Folsom, ca
    Could be a lazy lifter... low oil, low oil pressure.
    Could be a bad plug... somehow.. not sure.
    Bad wires, bad sticky EGR.
    Good luck.
  3. 83bowtyblazer
    Jul 29, 2001
    132
    Ft. Dix, NJ
    is it something I should look into right away??
  4. 83bowtyblazer
    Jul 29, 2001
    132
    Ft. Dix, NJ
    can anyone else help??
  5. 3car
    3car 1/2 ton status
    Dec 16, 2001
    976
    Hernando, Florida
    sounds like a lifter.when it looses pressure,the valve it opens dosent open fully,and that causes the idle to stumble.
  6. 83bowtyblazer
    Jul 29, 2001
    132
    Ft. Dix, NJ
    That makes sense. Thanks.
  7. oatsk5
    oatsk5 1/2 ton status Premium Member GMOTM Winner
    Aug 18, 2002
    1,724
    8
    Grand junction CO
    That sounds like a problem a friend of mine had and it was a sticking valve /forums/images/graemlins/thumb.gif
