directfitup carb?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by JimmyJuneau, Oct 9, 2001.
  1. JimmyJuneau
    JimmyJuneau 1/2 ton status
    Apr 11, 2001
    811
    Juneau, Alaska
    Is there a carb out there that I can buy and will be a direct fit meaning all the original vacume lines and gas lines are in the same place. Is there one of theses I can buy at a decent price? if so where ?
    It would need to go in a 85 with a 305 auto choke.
    1985 GMC JIMMY
  2. tRustyK5
    Jul 23, 2000
    36,180
    1,388
    E-town baby!
    Check with Autozone or pep-girls for a reman Q-jet for your year and engine. Should be a direct replacement.
    Rene
  3. dragricinMT
    dragricinMT 1/2 ton status
    Jul 21, 2001
    135
    Billings Montana
    Get the # off of your carb, then call the parts store. Give them that # and they will get you a direct replacement. Some years have more than one choice and this eliminates the possibility of getting the wrong one. The # will be on the left side of carb running from top to bottom.
    78-K5 4"Lift 35"Tires 400SB TH350 NP205
    73 Vega 350SB TH350
  4. Alaskan85K5
    Alaskan85K5 Registered Member
    Sep 5, 2001
    32
    Anchorage, AK
    Ebay :-) You may wan to look at E-bay for a reman or use Q-jet that will work. This is what I did, bought a Q-jet off e-bay and rebuild it. Some times you can find rebuild q-jets the usually have the # with the post. You can use that # and decode it to see if it will fit your. Your other alternative is buying from Schucks or Napa that they aren't cheap.
    Remove the NOSPAM from the e-mail address to send me an e-mail.
  5. Executioner
    Executioner 1/2 ton status
    Feb 22, 2000
    1,530
    Temp. Ft. Walton Beach Fl. home=Tucson, Az.
    Edelbrock makes one 190x-190x. You can get them from just about anywhere, mail order, or local.
    Good luck
