directions for a 700r4 tranny
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by scrappyk5, Jan 27, 2003.
  1. scrappyk5
    scrappyk5 1/2 ton status
    Mar 17, 2002
    2,099
    virginia
    i have a leak inside my bell housing area behind the torque
    converter. its running down the sides and collecting at the
    bottom while running. i assume i need to replace the shaft
    seal or the pump seal. hard to tell for sure untill i pull
    it. any special directions i need to replace these seals?
    this tranny is an 87 700r4. thanks
  2. R72K5
    R72K5 Banned
    Mar 5, 2001
    8,905
    central IL
    its the front seal, its just like a wheel seal, same deal, gottapull converter out to do it
    press it in evenly carefully
  3. scrappyk5
    Mar 17, 2002
    2,099
    virginia
    what about the pump seal , is that hard to replace ?
  4. Lonnie
    Lonnie 1/2 ton status
    Dec 5, 2001
    138
    Pittsburgh, PA
    Have a tranny shop check it while it is out... many 700r4's take out the front bushing in the pump as well causing this leak. Just changing the seal will give you the opportunity to do it again.
