Dirt Cheap Lift
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by BigBurban350, Jul 24, 2002.
  1. BigBurban350
    BigBurban350 1/2 ton status
    Jun 9, 2002
    711
    Michigan
    I got a stock 84' K-5 for $250 runs and drives. I want to put a lift on it the cheapest way. Would it be safe if I relocated the spring mounts down 6 inches with some thick angle iron welded to the frame.
  2. Shaggy
    Shaggy 3/4 ton status
    Dec 15, 2000
    6,737
    Los Banos, CA
    <font color="green"> I'm gonna go ahead and say <font color="red"> NO </font color>. If you engineer it a little better than just angle iron it might be OK, but you'd be better off to yank the springs and have them rearched to get some lift. You can just use blocks in the rear to go cheap also. Add a leaves are good for a couple inches too.
  3. HarryH3
    HarryH3 1 ton status Author
    May 31, 2000
    10,384
    Georgetown, TX
    Fill out your profile, so folks know where you're located. Someone in your area just may have a lift kit laying around going unused that they would part with for short money. /forums/images/icons/cool.gif
  4. MJF
    MJF 1/2 ton status
    Nov 1, 2001
    694
    Campbell, CA
    Yeah, fill out your profile. If you're close to me I might be able to hook you up with a used lift or at least the rear blocks.
  5. laketex
    laketex 3/4 ton status
    6,220
    North Texas
    new front tuff country springs cost me 240 bucks
    shackle flip was free
    But it's the little nickel and dime stuff that will get you down, so save up and do it right. I needed extended brake lines at $100 and new ubolts at $60. So we're talking $400 for a 4" lift that is really good, really safe, and not all rigged up. Please dont be another driving road hazard. When you space down your hangars like that, you severly increase the side to side torque load on them. It's not a matter of if, but a matter of when they break. And hopefully it's not when a carload of kids is right beside you.
