disable the ABS
Discussion in 'The Garage' started by Clockwork71, Nov 11, 2006.
  1. Clockwork71
    Clockwork71 Registered Member
    Mar 23, 2006
    23
    Waukesha,WI
    I have a 94 caprice 9c1. does anybody know how to disable the ABS?
  2. 1979jimmy350
    1979jimmy350 1/2 ton status
    Mar 24, 2004
    3,069
    Ann Arbor Mi
    unplug the ABS unit
  3. readymix
    readymix 3/4 ton status
    May 30, 2004
    6,706
    26
    Murrieta, California
    or pull the fuze
  4. pvfjr
    pvfjr 1/2 ton status
    Feb 10, 2004
    2,425
    Oakridge, OR
    Just do situps till they don't work no more.
  5. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    AB Lounger works better.
    Pull the fuse.
  6. stockk5
    Apr 13, 2004
    2,033
    71
    Cromwell, CT
  7. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    im a big fan of the ab roller myself, or the abdominizer. i'd pull the fuse too, as well as the bulb in the cluster.
  8. dhcomp
    dhcomp 3/4 ton status Premium Member
    Mar 17, 2001
    9,853
    280
    Truckee, CA
    If its the same as my 94 blazer, disconnect the power plug to the abs unit. Start the car, run it a little bit - brake/abs lights will be on. Turn off, plug unit back in. The trouble code set on teh computer makes the abs light stay on, and the system off. All you have to do to fix it is clear the codes.
    I'd leave the light in your dash, that way, other ppl are alerted to the fact that it isn't working.
    FYI my truck in 94 doesn't ahve a seperate ABS fuse to pull.....its a speed sensor fuse i think, which kills the speedo too.
