Disabling VATS w/o VIN or key?
Discussion in '1973-1991 K5 Blazer | Truck | Suburban' started by derek2002, Nov 18, 2000.
  1. derek2002
    derek2002 1/2 ton status
    Aug 1, 2000
    247
    Midland, Michigan USA
    Does anybody know how I could disable the VATS on a 1987 350TPI with the original chip and computer? I cant get my hands on the VIN or one of the original keys. If anybody can help me or know of someone to contact, please let me know. TIA!!!
    Late,
    -Derek
    1986 3/4 Ton & 1987 Blazer Project
    http://www.4chevy.com
  2. Grim-Reaper
    7,385
    Atlanta
    I belive you will have to have a new chip burned to disable it. I had a bud just put the TPI on his 72 and I know he had to have the chip burned to work with his motor and I belive they killed the vats at the same time.
    Diging it in the dirt with my K5's
    Grim-Reaper
    http://grimsk5s.coloradok5.com/
  3. DBLAZER
    DBLAZER 1/2 ton status
    Apr 2, 2000
    1,716
    Haslet, Tx
  4. derek2002
    Aug 1, 2000
    247
    DBLAZER-
    I have the complete wiring harness from the donor car... Let me know. Thanks!
    Later,
    -Derek
  5. edeslaur
    edeslaur Registered Member
    Oct 31, 2000
    69
    Portland, Oregon
    Derek,
    VATS is part of the chip & you will need a replacement chip to resolve it. I don't believe the aftermarket chips remove this, though I could be wrong.
    Go to http://www.diy-efi.org/gmecm/ and download the (big) archive. Search for "VATS RATS" which was a sizeable thread on VATs and the removal therof.
    Howell, Jet Performance, Hypertech would be other possible solutions.
    I'm still getting my one big toe wet, so that's all the info I have.
    Good luck,
    ERic D
  6. BurbinOR
    BurbinOR 3/4 ton status
    5,829
    Oregon
    The VATS is disabled if you have an aftermarket chip burnt........or is that burned [​IMG]. We had to have a custom chip burnt for my 406 because of the motor size, cam and 24 lb injectors, and first cut the dude forgot to disable VATS, fixed it and no problemo.........costs around $100 for a new custom chip too.
    <font color=black>'79 - 406 TPI -<font color=orange> K5#5 - <font color=blue>See it at---&gt;http://www.blazzinor.coloradok5.com
  7. DBLAZER
    Apr 2, 2000
    1,716
    Haslet, Tx
    I normally bypass the vats when I am adding an alarm with a remote start system. I bypass it at the steering colum with the corect resister. Ill send you the info that I have on monday. Do you have a fax number????? Let me know.
    http://dblazer.coloradok5.com
