Disappearing H2O
Discussion in 'The Garage' started by bigbluesuburban, Oct 29, 2006.
  1. bigbluesuburban
    bigbluesuburban 1/2 ton status
    Feb 8, 2006
    1,362
    Constant State of Perpetual Anger
    I am adding water every 2-3 days to my radiator. I can tell when it gets low because the heater works and the temp skyrockets when an airbubble surrounds the temp sensor.
    I have no visible leaks and I don't smell burning antifreeze. The oil is not milky and everything else works great
    SOOOOO... Where the heck is the water going?
  2. beater_k20
    beater_k20 Banned
    Dec 9, 2003
    10,276
    Elkhart, IN
    replace your radiator cap. i've seen alot do just that when the radiator cap is bad.
  3. 79k20350
    79k20350 3/4 ton status
    Nov 22, 2004
    7,757
    Ct
    check under you carpet...possible leaking heatercore.
  4. roadnotca
    roadnotca 3/4 ton status
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Your leak might in the fins and tubes of the radiator core, and evaporating before there's enough to drip.
  5. bigbluesuburban
    Feb 8, 2006
    1,362
    Replaced the cap with a pressure release cap to make refilling easier. AND... replaced the overflow reservoir cap because the rubber inner grommet went missing... Water still disappearing... Dangit
  6. bigbluesuburban
    Feb 8, 2006
    1,362
    No wet carpet... I am REALLY glad about this!!!
  7. bigbluesuburban
    Feb 8, 2006
    1,362
    Hmmm... I guess I should pressure test the system then huh? Ok well I am off to NAPA tomorrow to buy a cooling system pressure test kit.
  8. bigbluesuburban
    Feb 8, 2006
    1,362
    Ya know, I just thought of something. I disconnected the rear heat because it intruded in the cargo area too much. I need to check all those hoses and make sure that my "bolt&hose clamp" heater hose sealing system is still functioning properly.
  9. sandawgk5
    sandawgk5 3/4 ton status
    Oct 28, 2003
    6,881
    Kitsap County PACNORWEST
    I was loosing water and it was coming out of the weep hole on the waterpump. No visible leaks anywhere I noticed my waterpump shaft was not tight as it wobbled when the engine was running. I replaced it and no problems
    Ira
  10. Slapperbar
    Slapperbar Retired Navy NDT Examiner Premium Member
    Nov 29, 2005
    2,747
    3
    Harrison City, Pennsylvania
    Could be the intake front passage. Gasket may be bad and you're ingesting it in either #1 or 2 cylinder.
  11. 79k20350
    Nov 22, 2004
    7,757
    Ct
    id be wiling to bet that this is your cause...
  12. roadnotca
    Sep 16, 2005
    5,433
    Redondo Beach, CA
    Rear heat, WOW! I've only seen one of those in print.:D
  13. bigbluesuburban
    Feb 8, 2006
    1,362
    I kept the heater core just incase I decide to put it back in more out of the way than the original installation.
